Comfort Audio's Comfort Contego is a wireless digital secure high-definition FM HD sound communication system for people with mild to severe hearing loss. This version includes an earphone and headphone. Achieve up to approximately 40dB amplification at 1kHz.
The Comfort Contego is the only wireless system that transmits high-definition digital sound over secure channels. This feature makes it a good option for those who desire a secure communication system that cannot be eavesdropped electronically (courtrooms business government offices etc.).
Ease of UseThe flexibility of the Comfort Contego system allows an unlimited number of additional receivers to be used with one transmitter making this an ideal solution for guided tours classrooms courtrooms etc. Both the transmitter and the receiver have built-in microphones that can be set for omnidirectional or directional depending on the environment.
Comfort Contego is a practical solution for the work environment such as in meetings groups seminars or lectures. At home the system can be used at the dining table while watching TV or with other sound sources. While out and about (in restaurants the car stores etc.) the system helps reduce background noise to focus on desired sounds. The receiver itself may also be used as a standalone personal listener. A telephone kit is now included for improved communication on the telephone!
RangeWorking range is approximately 100 feet depending on the type of environment you're in. It can achieve up to 20 hours of use (under normal conditions). The Contego uses Li-Ion rechargeable batteries.
This Contego system comes with an earphone and headphone.
Features
