DRIVE MEDICAL 14029 MED AIRE PLUS 8 INCH LOW AIR LOSS PUMP AND MATTRESS REPLACEMENT SYSTEM WITH APP AND LOW AIRE LOSS
Pump can be used as static or alternating pressure device. Ideal for use in nursing homes hospitals and home use. LED and Audible alarm activates when pressure falls below 10mmHg. Easy to replace individual bladders. Cell in a Cell design prevents the mattress from bottoming on the bed in the event of power failure. High volume pump produces 8 liters or air per minute. Mattress has 20 air bladders 9 with laser cut low air loss function to increase patient comfort: helps keep the patient cool and speeds recovery. 8 cells are constructed with Nylon/TPU that is soft lightweight and will not stretch. The zippered cover features a TPU material on the outside that is heavy weight and a polyester material on the bottom that is lightweight and durable. The cover is water resistant vapor permeable has a fiber quilted bottom and is machine washable to provide protection and comfort. CPR emergency valve provides fast release of air. Water resistant permeable cover. Warranty: 1 year.
Price: 1299.75
