DRIVE MEDICAL 14029DP MED AIRE PLUS 8 INCH DEFINED PERIMETER LOW AIR LOSS AND ALTERNATING PRESSURE MATTRESS REPLACEMENT SYSTEM PUMP AND MATTRESS SYSTEM
Static perimeter tubing surrounds the length of the mattress preventing the patient from becoming trapped between the mattress and rails and increases patient safety during transfers. Pump can be used in a static or altering pressure mode. Ideal for use in nursing homes hospitals and home use. Perfect for the prevention and treatment of decubitis ulcers. LED and Audible alarm activates when mattress pressure falls below 10 mmHg. Cell within a cell design prevents the patient from bottoming out in the event of power failure. High volume extra quiet pump produces 8 LPM. Mattress has 20 air bladders 9 with laser cut low air loss increase patient comfort: helps keep the patient cool and speeds recovery. Low air loss helps keep patient cool and comfortable increasing healing rates. 8 cells are constructed with Nylon/TPU that is soft lightweight and will not stretch. The zippered Nylon/TPU cover material is heavy weight water resistant vapor permeable has a fiber quilted bottom and is machine washable to provide protection and comfort. Specially designed 3 tube pump and pad system quietly operates low air loss system while maintaining perimeter. Spring lined tubing prevents kinks and helps maintain airflow. Quick fill adapter standard. CPR valves for fast (20 second) air release. 450 lb. Weight Capacity.
Price: 1666.81
