DRIVE MEDICAL 14030 MED AIRE BARIATRIC 10 INCH MATTRESS AND PUMP REPLACEMENT SYSTEM WITH APP AND PRESSURE ALARM BARIATRIC LOW AIR LOSS
Ideal or use in nursing homes hospitals and home use. LED and Audible alarm activates when pressure falls below 10mmHg. Cell on Cell design prevents the mattress from bottoming on the bed in the event of power failure. High volume extra quiet pump produces 15 liters of air per minute. Mattress has 20 air bladders 9 with laser cut low air loss function to increase patient comfort: helps keep the patient cool and speeds recovery. Low air loss helps keep the patient cool and comfortable increasing healing rates. 10 cells are constructed with Nylon/TPU that is soft lightweight and will not stretch. Quick fill adapter standard. CPR valves for fast (20 second) air release. 750 lb. Weight Capacity. The zippered Nylon/TPU cover material is heavy weight water resistant vapor permeable has a fiber quilted bottom and is machine washable to provide protection and comfort. CPR emergency valve provides fast release of air. Water resistant permeable cover. Warranty: 1 year.
Price: 2151.99
