WILLIAMS SOUND PPA T46 PERSONAL BODY PACK TRANSMITTER
The Personal PA T46 transmits in 72-76MHz broadcasting a speaker's voice or audio program on one of 17 available channels to listeners with headphones earphones or neckloops using R35-8 or R37 receivers or the R1600 Williams Sound speaker. The unit features flexible microphone and auxiliary inputs push-button on/off/mute controls channel lock and selectable compression.
The T46 has the ability to operate in dual channel mode allowing the user to easily switch between two different transmitting channels each with its own set of parameters. An OLED screen displays the T46 transmitter's current operating status and menu information.
Features:- 17 channel selectable 72-76MHz.
- Digitally synthesized frequencies.
- Sleek ergonomic design.
- 1-1/4" OLED interface displays: volume level mic mute settings lock battery level.
- Easy-to-use menu-access controls.
- Mic input accepts electret mic with 3.5mm mono plug.
- AUX audio input accepts 2.5mm stereo plug (MP3 CD player).
- Range up to 150 feet (45.7m) with PPA R37 receiver.
- Push button On/Off/Mute control.
- Flashing Mute and Low Battery indicator.
- Operates in Normal or Compress (2:1) mode.
- Mic and auxiliary volume controls.
- Channel lock switch.
- Belt clip for hands-free use.
- Uses 2 AA alkaline batteries up to 30 hours battery life or 2 AA rechargeable batteries up to 20 hours battery life.
- Meets ADA guidelines.
- Approvals: FCC Industry Canada RoHS WEEE.
- Dimension - 4.1 L x 2.8 W x 1.1 D in.
- Item Weight - 1 lbs.
Price: 653.90
